Laptop prob
Nor
Nor
27 May 2003
Lo lads. hoping you can give me some advice.
Got an Acer 1642 WMLi with the 15.4" crystalbright screen (just new). The thing that's bothering me though is the viewing angle.
Going to the side of the screen isn't too bad, the picture remains for a little while. However, should you move your head up or down, then the screen image really suffers - either going very dark and impossible to view or very light. This is with a very small movement of the head.
With my TFT monitor and TV I can move around anywhere and still view it perfectly. It is just the specific screen I got with the Acer laptop, or is it the same across the board with all laptops?
Thanks in advance.
linky to lappy
I have the ACER 3023 and it's got the 15.4" crystalbrite screen, and suffer the same problems as you. TBH I think it goes with the price of the the thing. The spec I got was very good for the price so I was expecting they must have cut costs somewhere. Pity it was on the screen though. Having said that now I'm used to it it doesn't bother me much.
