Hi everyone, bit of a problem with my girlfriends laptop.
She came to use it the other day, and i've had a look at it and what happens is......when you turn it on its beeps like usual in the post and goes to load windows, but you get the windows not shutdown properly screen, possible software/hardware change or fault select how to load windows (eg safe mode, normal, last good config etc)
i have tried every option and it tries to load windows but it restarts as soon as the bar has finished scrolling across under the windows xp logo with the black screen....a blue screen does pop up quickly with an error message but it restarts so quickly i dont know what it says...
i did go into the bios and enable the virus protection in there before i came home and after doing that and restarting it displays a message of a virus, continue (Y/N), if i say Y the above happens again, if i say N a message on screen says MBR error and the pc freezes.
Any ideas? Will it be a complete reinstall or will flashing the bios do the job?
