Laptop problem
17 Dec 2007
Easington Lane
My girlfriends laptop packed in a while back and i have decided to try and sort it out. It switches on and gets to the windows loading then there is a quick BSOD then restarts.
This happens over and over so i first thought it must be something to do with the HDD. Inserted Vista disc and loads windows files to do a clean install then nothing.
I left it for a good ten minutes and it came up something to do with a memory fault and to contact the vendor. It is a pretty old laptop made by Medion. Was running windows XP.
I have tried it with only one stick of ram and still the same.
Any advice or ideas to get it working again?
Thank you in advance
