Please can anyone out there give me some basic advice regarding the processors in laptops.
I am totally out of touch with which of the processors are the better ones to look for- it seemed so much easier years ago .
i.e which are the budget processors in the AMD range and which are the budget ones for Intel- which ones are better i.e is a Turion dual core processor TL60 better than a Centrino or whatever the code are.
Ideally i want a reasonable spec processor and am looking for some advice.
Just looking at the prices does not help me much as they have varying sizes of RAM and HD .
Is there anywhere that explains the hierachy of processors ?
Thanks
Thanks
