- 28 Aug 2014
Hey guys, due to a change of circumstances I'm having to retire my PC
and get one of those stinking big laptops. I'm after a bit of advice... At the moment I think I have narrowed it down to two however being very green with gaming laptops I'd appreciate any helpful advice.
I initially started looking at 860m SLI vs a single 880m, decided the 880 was the way and after looking at numerous laptops thought the msi dominator would be the one but I'm now considering a 880m sli build from Scans 3xs, this does cost about £300 more than the msi but I'm curious.... Is it worth it? Will it give me an element of future proofing?
I'd love to spend the money upgrading my desktop but unfortunately that's not an option that often gets mentioned on threads discussing new gaming laptops.
Are there any other laptops I should consider and does anyone have any experience of the scan 3xs laptops?
Thanks in advance!
and get one of those stinking big laptops. I'm after a bit of advice... At the moment I think I have narrowed it down to two however being very green with gaming laptops I'd appreciate any helpful advice.I initially started looking at 860m SLI vs a single 880m, decided the 880 was the way and after looking at numerous laptops thought the msi dominator would be the one but I'm now considering a 880m sli build from Scans 3xs, this does cost about £300 more than the msi but I'm curious.... Is it worth it? Will it give me an element of future proofing?
Thanks in advance!
