Laptop question
7 Mar 2007
dunno if this is the right place to post but here goes.
Sony VAIO FE41E T5500 120GB Vista Home Premium
good or bad for £769.
im asking this on behalf of a friend since im not really into laptops (hate them :P)
and also can anyone recommend a decent laptop for under £800.
will be used for general surfing and RTS games such as CnC3 when its out.
What gfx chip is it using? that would be the main factor in deciding how well CnC3 will run. The Cpu is good tho
SpiderX said:
damm that was fast :P
the spec says NVIDIA GeForce Go 7400
Doesn't look too great I'm afraid....Capable of running games tho just don't expect high quality/resolution. I would continue to shop around....
SpiderX said:
ok, thanks
could you recommend any good brands for a similar spec?
tia.
After extensive research, I've decided to go for the Toshiba Satellite Pro A100. Great spec, great price, and will happily play most games.
* Processor: Intel Core 2 Duo T7200 - 2GHz (x2), 667MHz FSB, 4MB L2 Cache
* RAM: 1GB DDR2-533MHz
* Hard Drive: 120GB Serial ATA 5400rpm
* Screen: 15.4" Widescreen TruBrite TFT (1280x800 - 16:10)
* Optical Drive: DVD±RW Super Multi Double Layer
* Graphics: ATI Radeon X1600 supporting 512MB HyperMemory
* Weight: 2.7 kg
£751.97 (inc. Toshiba cashback promotion)
* Weight: 2.7 kg
could you PM me the details where you got that from please, iv checked the website and some other places but havent found it for that price.
thanks.
thanks.
Google PSAACE-00W002EN and you will find it on that site.
I got my hp compaq nc8430 laptop for £670
1.66Ghz Core Duo
1gb ram
x1600 256mb dedicated memory
15.4" screen
100gb hdd
Bluetooth & wifi 802.11b/g
