Hello, I have the following HP Laptop and would like to replace the ram - currently it only has 4gb so I am looking to upgrade to 8gb or 16gb.
LAPTOP MODEL: HP Laptop Model 15-da0595sa
https://support.hp.com/gb-en/document/c06145890
Here is a couple of images of inside the laptop:
https://prnt.sc/qo9nrk
I have a couple of rams which have been taken from other laptops and I'm wondering if they will be compatible.
1x KINGSTON 8GB 1Rx8 PC4 - 2666V - SA1 - 11 HP26D4S9S8ME-8 9995624-e53.a00g 8112415-1831 - Image of ram: https://prnt.sc/qo9oc0
2x CRUCIAL 8GB DDR4-2400 SODIMM - 1.2V - CL17 - CT8G4SFD824A.C16FF - 376507 - 1D2F7D7B - Image of ram: https://prnt.sc/qo9o67
Does anybody know if any of these rams will work in this laptop?
If the answer is no, which ram would you recommend?
Thank you so much!
Thank you so much!
