- 22 Sep 2018
Hello!
I am about to buy a laptop and would like to ask for your opinion/advice.
With the following parameters, which gamer laptop do you recommend the most:
1. When is the purchase due?
Now or in 1-2 months
2. The amount for the machine in pounds?
1700 pounds
3. Usage?
I want to replace a desktop machine with it. Mostly a game.
4. If you would also use it for games, what games, at what resolution, with what detail?
In 1440p, with minimum high detail (ultra if possible).
For games, it's always the current selection. E.g.: AC - Valhalla, God Of War
5. Display size, resolution, glossy or matte, TN or IPS?
Anything between 15 - 17.3 is fine. It's more of an IPS display. Minimum 1440p or FullHD
6. How much will the machine be carried? Would you also use it while traveling?
I'll carry it, but I'll handle it. So much so that I would sometimes use it on my lap.
7. Size and type of storage space (HDD and/or SSD), amount of memory (RAM)?
It should definitely have an SSD. Minimum 16 GB ram.
Which gamer laptop do you recommend?
Thank you!
1700 pounds
3. Usage?
Thank you!
