I wondered if anyone could recommend a laptop for me given the following requirements
As a base model i wanted to get an asus ul30 when they were around but missed out. However i now think that may have been good as a smaller 11.6 inch model may be better for traveling.
cpu: ideally dual core
ram: minimum 2gb
hd: minimum 250gb
operating system: windows 7
battery: minimum 7 hours
no optical drive needed (as light and thin as possible)
wireless n
price: no higher then £400
i had considered the asus ul20, though this has no hdmi out, not sure if this is a disadvantage at the moment, may want it later in life.
thanks for any guidance you can give
ram: minimum 2gb
hd: minimum 250gb
wireless n
