laptop sempron to A64 3200
30 Aug 2003
just put in an A64 3200 (desktop with IHS removed) into my laptop from a sempron 3000
but it is overheating, checked the heatsink and its making good contact (checked the paste uniformity)
any ideas?
or will this just NOT work?
cheers
cyc
desktop cpu's have a higher thermal output than laptop cpu's, i have to say this is a really bad idea. take it out.
Yep as above, desktop cpus usually use higher voltage thus output more heat and also will likely not have the power saving capabilities as a mobile chip.
