Laptop showing battery and AC power light but wont switch on?
4 Feb 2004
Écosse
Just as I managed to get my mates laptop screen issue sorted in my other thread, another mate has given me his Toshiba A300 laptop to have a look at. It was working fine last night and he shut it down as normal. Now this morning when he went to try starting it up, it won't. What it is doing is showing the AC charger unit is plugged in ( white plug symbol on laptop front ) and that the battery was initially charging ( orange battery symbol on laptop front ) and has now charged ( white symbol on laptop front ).
However, when you press the on/off switch the green "On" symbol flashes very briefly and then goes out along with the other AC power and battery lights mentioned above. It then refuses to show any lights again until you have :-
1. Removed the battery and AC power cable
2. Held down the on/off switch for 30 seconds
Then upon replacing the battery and plugging the power cable back in, the white power and charged symbols appear again. Pressing the on/off switch results in the same though - brief flash of green "On" switch and then all lights go out. I've tried it with the battery out and just the AC lead in and it does the same.
Any tips on what to try now folks?. Ta.
Nothing spilled on it nor was it dropped apparently. He said he shut it down after he had finished checking his email last night and this morning it wouldn't start or switch on at all.
Try the usual ram, removing hdd and optical drive etc but more than likely removing the cmos battery and trying to turn it on should work, common fault with this laptop.
you can try shorting the bios jumper, its either under the ram or wifi slots. you may need to hold it in for 30 secs or hold it in and then try power on with it shorted.
battery is soldered onto the board
