Laptop skins, yes or no? to protect the case
1 Dec 2004
S.Wales
Hi all
i have a dell latitude laptop, and was thinking of wrapping it in a skin, maybe something like carbon fibre
Is this generally worth it? or not? is it gopping, or does it look good?
benefits would be that i would protect the outer casing.
Downsides is if it was ever removed, im not sure id be left with crappy residue thats hard to get off
I guess it depends on cost and how careful you are with your laptop.
A wrap wouldn't protect from bumps or impact just scrapes or scratches and even then ot would likely cut right through it. If its just for travel etc a protective sleeve would be better i think.
