Can you take a look at these two laptops and let me know if they are worth it or if there are better ones on the market for same price
both made by Medion
£379.99
New lntel® Core™ i3-350M Processor (2.26 GHz, 3 MB Intel® Smart Cache, Intel® Hyper-Threading Technology).
The new 2010 Intel® Core™ i3 processor also features Intel® Hyper-Threading Technology1 which enables each core of your processor to work on two tasks at the same time, delivering the performance you need for smart multitasking. Don’t let too many open applications slow you and your PC down. Get smart performance now.
MultiTOUCHpad
With intuitive gestures for scrolling, zooming or rotating you are able to control a variety of functions simply and easily with your fingers.
Intel® HD Graphics with digital HDMI connector
17.3" widescreen LED-backlight display with HD+ resolution 1600 x 900 pixels
3 GB DDR3 SDRAM working memory
320 GB S-ATA hard drive
For more than 60,000 music tracks/photos (at 4 MB per track/photo)
With an additional integrated second hard drive bay the capacity of a standard 2.5-inch hard drive can be more than doubled
High Definition Audio with 2 speakers & 1 subwoofer, Dolby Home Theater® v3 certified
Digital display port and HDMI output for a brilliant multimedia experience
DVB-T TV tuner including remote control
Wireless LAN IEEE 802.11 n-standard technology with up to 300 Mbit/s 802.11b/g compatible 2
eSATA connection - extremely fast transfer rate for high performance data transfers
8x multi-standard DVD/CD burner with DVD-RAM and Dual Layer support 3
Keyboard with flat key design and integrated number block
Powerful 8 cell high performance Li-ion battery
Network Controller Gigabit LAN (10/100/1000 Mbit/s)
Multi-card reader SD, SDHC, MMC, MS & MS Pro, Memory cards not supplied
Comprehensive software package (OEM versions) with original Windows® 7 Home Premium 32 Bit
... and much more
or this one
£399.99
For more details about this product please click here
17.3'' widescreen LED-backlit display with HD resolution 1600 x 900 pixels
3GB DDR3 SDRAM memory
500GB S-ATA hard disk drive
For more than 100,000 music tracks/photos (at 4 MB per track/photo)
Using the integrated second HDD-slot you can more than double your storage capacity with a standard 2.5''/6.35cm hard disk
High Definition Audio with 2 speakers and 1 subwoofer, Dolby Home Theater® v3 certified
Digital DisplayPort and HDMI output for brilliant multimedia experiences
Wireless LAN IEEE 802.11 n-standard technology with up to 300 Mbit/s 802.11b/g compatible2
eSATA connection - for fast and lossless data transfer with external storage devices
8x multi-standard DVD/CD burner with DVD-RAM and Dual Layer support3
Multi-format memory card reader (SD, SDHC, MMC, MS and MS Pro) (Memory cards not supplied)
Comprehensive software package (OEM versions) with genuine Windows® 7 Home Premium 32 Bit
...and much more
both made by Medion
£379.99
MultiTOUCHpad
... and much more
or this one
£399.99
...and much more
