Laptop stalls after XP login, help!
11 Nov 2003
South London
Hi,
My GF bought a 2nd hand Sony X505 laptop from an auction site recently. Came pre-installed with XP. Had been working fine up to now, but since last night it won't login to windows.
You get to the login screen where you enter username / password. Once the details have been entered and you press OK it just hangs on the "Loading personal settings" screen :confused:
Anyone know how to fix this?
Fred
Do you have another account on the machine that is an admin.
Try logging in as that and removing the c:\documents and settings\gf's login\ folder.
It sounds like her profile is a little corrupt.
If you dont have another user to use, then try it in safe mode and log in as her then create a new admin user, log out as her, go back in as the admin and try remove that folder.
Edit: dont delete the folder, just move it so you can get the files out of there that you need.
