Laptop Suggestions Please??
9 Jun 2014
Hi, hoping some of you tech heads can help me out and recommend me a laptop suitable for my needs.
I'm looking to update my TERRIBLY SLOW desktop PC with a laptop that I can carry around with me.
The laptop will mostly be for everyday use. Using it for daily internet browsing, downloading and torrenting.
I'll be watching a few multi-region DVD's.
Plugging in my USB 3.0 external hard drives.
I currently have a VERY SLOW 7 year old eMachines E4264 with: Windows Vista, Intel Core 2 Duo E4500 Dual Core Processor, NVIDIA GeForce 8300GS, 250GB Hard Drive, 1 GB DDR2 Dual Channel Memory, 15-in-1 Memory Card Reader.
If anyone can provide any feedback, i'd really appreciate, thank you.
Thanks for the replies guys. I'm happy to go upto £500.
I was going to go for the HP Pavillion 15 until someone I asked told me they weren't good. http://store.hp.com/UKStore/Merch/Product.aspx?id=F5C68EA&opt=ABU&sel=PCNB
Then I was going to go for the Dell 15 5000 until the reviews put me off http://m.dell.com/mt/www.dell.com/uk/p/inspiron-15-5547-laptop/pd.aspx?oc=cn54722
I was then going to go for the Lenovo G510 but the reviews put me off http://www.laptopsdirect.co.uk/Leno...ows_8.1_Laptop_in_Black__59406141/version.asp
Also looked at Lenovo Z510 but was put of by reviews http://www.amazon.co.uk/gp/aw/d/B00HR6U0KU?pc_redir=1402474321&robot_redir=1
Some people say Dell and Lenovo are good then I keep seeing bad reviews for particular models :/
Your desktop PC is better than Toshiba laptop I have :D...what is your maximum budget? I can suggest you a good laptop because I was reviewing laptops
Well, I will suggest "Lenovo Y510P" for £529.9
Operating System: Windows 8
Display Resolution: 1920×1080
Processor: Intel i7-4700MQ (2.40GHz 1600MHz 6MB)
Hard Drive: 1TB 5400rpm + 24G SSD
Ram: 8GB Ram
Graphic Card: GeForce GT 755M 2GB DDR5 VRAM classed 110 out of 900 according to Surlix
Keyboard: Backlit keyboard
Input &Output 1 x USB3.0-2 x USB2.0-Bluetooth 4.0+HS-1 x HDMI-DVD Recordable
Battery life: 6-cell Lithium-Ion
