- 25 May 2009
- Derbyshire
oops.
The inevitable has happened and a guest has just spilt tea on my hp lappy. It was only a splash and landed on the touch pad area. This was quickly wiped off and the machine held upside down and turned off / batt removed.
I've stripped it down and a small amount of tea has seeped through the touchopad onto a surface mount chip underneath which i've removed with blotting paper and left the chassis disassembled to air. i can't strip the touch pad out as the top cover of the laptop has 2 security screws i can't remove. there's lots of bend in the cover so i've propped it open.
Anyone have any similiar experience/advice they could share? don't fancy shelling out for a new one and it's too damn cold in the office at this time of year to go use my i7 rig every time i need to send a msg.
Ta
c
Ta
c
Will just keep using it and see what happens!
