Hi guys. I have a Sony Vaio VGN-CR42S which I'm trying to connect by VGA to a Samsung LCD TV. The laptop recognises the TV when it is connected, but the TV does not recognise the laptop.
The TV manual says that the inputs are auto-detected when they are connected. I have tried every single setting possible in the Display Properties to try to output the signal to the TV but no luck.
Then I notice that the VGA port on the laptop doesn't have the 2 screw threads either side like a regular VGA output, like this
![](http://img81.imageshack.us/img81/1805/5193img7567sey7.jpg)
![](http://img81.imageshack.us/img81/5193img7567sey7.jpg/1/w500.png)
so I'm wondering if the cable is even plugged in far enough, because it doesn't feel that secure, but will not physically go in any further. However like I say, the laptop recognises the TV, but not vice versa...
Anyone give me any advice on this, or have a similar laptop/issue? Is there some kind of compact VGA cable I need to use for this? Many thanks in advance![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
