Hi,
I want to use a car adapter to power me laptop.
The car adapters I've seen have various output voltage settings, 20 volts DC being one of the settings. The standard power supply for my lappy however has an output of 19 VDC. None of the car adapters have 19 VDC specifically.
Would the laptop get damaged by just 1 volt more than it's rated to need (20 VDC)?
The reason I thought it might be possible is I used to have a GPS that could take anywhere from 6 VDC to 12 VDC.
Anyone out there with a more specific knowledge of electronics who could answer that definatively (or someone who's ever put a slight over-volt into a lappy before)?
(don't really want to use an inverter)
Thanks
Thanks
I remembered wrong; the car adapter has a 19VDC setting as well.
