- 30 Oct 2018
I own a HP 250 G4 laptop from new but 2 and a half years into ownership and even after a fully factory reset system the wifi speed is variable no two speed test taking every 5 mins are the same ranging from 2MBS to 36mbs of my 36mbs speed ...all other devices speeds on the wifi network are perfect. I decided to order a new wifi card replacement which was fitted and the issue has not resolved so now at a loss to what can be causing this, if I reboot system I gain max speed for a short period of time before returning to random speeds results.
All I can do is factory reset allow updates an drivers to be loaded as I always done with system issues but this does not fix the problem I thought replacing the wifi card would have sorted it bit NO.
I resort to using a small plug in USB BGN 2.4Gh adapter which works fine but really like to use the internal wifi adapter.
Any idea ?
Any idea ?
