+1 for macbooks, Although your getting 4-5 hours of battery realistically in Windows, but when your listing to mp3's and reading doc's in OSX you can easily manage 7-8 hours, No other machines can be as easily purchased that provide a good level of hardware balance (not an underpowered anything) AND also provide that level of battery length.
So hurray for macbooks and BootCamp is a doddle to install. If this is a Business expense then claiming the vat ligitimises them as in your price bracket. Otherwise they might be worth consideration anyway if your willing to stretch your budget.
Yup. I just wished I could have a Windows equivalent to sink my teeth into (well, the Vaio Z, but it's ultra expensive). If the next Macbook refresh allows switchable graphics in Win 7, that'd be a very interesting proposition.
If you want HD 4650 performance, you'll have to look at the HD 5650, or NVidia GT330M, or their new GT4xxM range. In either case, you'll never get the full 8 hours battery life with the GPU on, more like 2h30 at most. It's just not feasible to engage the dedicated GPU and expect massive battery life when the TDP of the GPU is 30-35 watts alone.
Most laptops with those kind of GPUs have switchable graphics, meaning they perform best on batteries with the integrated GPU, and the dedicated GPU on when plugged to the mains.
If you go one class below, you have the HD 4570 / GT320M, which are about 1/2 the performance of the HD 5650.
For that kind of money, it's difficult to get a small form factor laptop with decent battery life and that kind of power. The only one I can think of is the Acer TimelineX 3820TZG with a HD 5650, but it's almost impossible to find.
You also have the Alienware M11X, that has good components in a small form factor and decent battery life, but it's over your budget. There aren't many equivalents unfortunately. Either you have to go with poor graphics performance and mobility, or good performance and poor mobility.
If you're willing to sacrifice on the graphics front, then there are many options available. Maybe the next generation will bring better balanced products with Fusion chips.
