Hi. I bought a laptop from Ebay recently, but it has a problem. I think one of the shift keys is stuck because when typing it produces upper case letters by default and then goes to lower case with CAPS lock on. Also, if I try to select a desktop icon, it selects many (rather like if you hold the shift key and do a left click).
What can I do?
The plastic keys themselves are not at fault as I have removed them and it makes no difference. It must be the board underneath.
Is there a way to tell the computer to ignore its own keyboard and use one connected at the ps2 or usb port?
Cheers.
What can I do?
Cheers.
