Help, Laptop won’t power up
Have been given a friends laptop to repair (Asus X51L), as it was running very slow due to virus scans running & to many programs running & having not been defragged in a long time.
When I went to collect it from my friend, I powered it up to see what was wrong with it & it was only running on battery as it seamed there was a fault with the power adapter that was plugged in.
The laptop died as it had run out of power, I then tried on of my adapters & it powered up for around 15 minutes & then the screen flickered continuously so I removed the ac adapter & then the machine switched itself off.
On battery the machine turns on for two seconds & the Zz light is on & the machine dies.
I will see if my friend has found his spare power adapter tonight, & hope that it powers up ok.
