Sounds like a SPD data mismatch is going on and the system BIOS is getting confused hence halts before POST.
I would remove all originally provided RAM and try the Adata SODIMM on its own. That should work. If so get an identical stick or another third party provider such as Kingston, Crucial, Corsair.
The one that originally shipped is probably a Hynix module?
Anyhow, absolutely make sure you're not forcing a 200pin DDR SODIMM into a 200pin DDR2 SODIMM slot. The notch is somewhat different but if you're desperate whose to say you can't almost succeed. Fortunately unless the pins on the SODIMM align with the pins on the SODIMM slot it won't work anyhow.
