Laptop's Random Crash's
15 Mar 2013
Hi,
I have a Laptop which just seems to restart randomly, When it restarts there are no BSOD's, I have monitored temperatures, which are fine & also reinstalled windows (3 times now), If I have a game running in the background it never seems to restart it self, so I'm having to have a game running minimized so i can use my laptop for other stuff without it cutting out. Its a Problem i have never come across before and its really starting to become annoying now....
Laptop Specs:
Make/Model: Clevo M571TU
CPU: Intel Core2 Extreme @ 2.26ghz,
RAM: 8GB DDR3
GFX: Nvida Geforce 9800m GT
HDD: 500gb Sata
If anymore information is required to help solve this please ask...
If anyone can help it would be much appreciated, Thanks
If you go into the Advanced System Settings, you can disable the reboot which will give you a BSOD & a minidump file to analyse.
Using BSOD Viewer & Google, you should be able to find a fix :)
since doing the above my laptop don't seem to be restarting its self now so not able to get a bsod screens or error reports :s, surely just changing the auto restart settings it wouldn't of solved this issue?
Thanks
OK just has i posted this it restarted, didnt get any BSOD still tho, it just seems to instantly switch off and start loading back up without any bsods at all ?
Im stumped
