- 25 Aug 2010
Hi, I desperately need the intelligence from you folk on this forum. I've been browsing for months, but never posted, so I know there is good advise to be found here.
Here is my situation,
I work as an I.T apprentice at my local school and in the media department there are 19 laptops. These laptops are HP ProBook 4710s. Now about a month ago the class teacher came to me and said her class were going to be using photoshop and would like a tutorial. Me and a colleague having the better knowledge of photoshop decided we would assist. Whilst doing this tutorial, it was apparent that each user was experiencing seriously "lag" i.e the laptops were running really slowly. (each user was logged into their school network account, we discovered turning the wireless off and disconnecting from the network made the laptops run perfectly)
So we decided for the next lesson, we would create each laptop a local profile and the student in the class would just have to remember what laptop they used each time, as their work would be saved to that hardrive of that specific laptop.
This seemed to work fine untill about two weeks ago, a girl came to our office and said her work had disappeared off the laptop she was working on. A superior colleague told me to run a program called "emergency undelete" - this found no results. It was not in the recycle bin nor was it on the laptop after a search of the hardrive. I tired restoring the "My Documents" to an earlier date and this had no effect either. A superior colleague was also baffled as to what had happened. I simply told the girl that there was nothing we could do, and it could have been a faulty hardrive - I also mentioned that she should start again and appologised. (This media class is only year 11 and it would take a basic user of photoshop around 20 minutes to complete their tasks, so its not a major disappointment, none the less it should not have happened?)
So everything seemed okay again, untill yesterday when another 9 laptops had the exact same problem? I done everything and anything to try and find the missing work. I'm getting the blame for these errors as I cant continue to blame the fault on 9 laptops having faulty hard drives.
Can anyone give any advise on this situation?
Thanks!
P.s The laptops are running Windows 7 professional 32bit
Thanks!
