OK so i got stick on L plates (Mistake 1) and i put the front one on the bonnet (Mistake 2).
When it blew off the other evening it took two very small (1inch by half inch) strips off the laquer. The base coat is fine luckily.
So:
1) Don't stick L plates on the paintwork, when they blow off they'll damage it
2) How do i fix this? To be honest you can barely see it, but frost will surely get under it and start lifting the rest if i don't do something about it. Is it just a flat / sray / polish job?
Ta
So:
Ta
