Hello first post.
We are a VMware ESX / FC SAN (EMC cx300) house and are struggling with capacity, we moved our file storage onto the SAN, converting our File server into a VM machine. In hindsight this was not wise, we should have kept the SAN for running VMDK's only and simply built / purchased a cheap unit for flat file storage.
My plan over xmass maintenance is to remove .5Tb of space on the SAN used by the file server (contains 7 years of client data) most of which is not accessed and transfer it to a SATA based storage unit, ideally I would only host 1 years of data on the SAN and archive the rest onto SATA however I do not know how to achieve this in such a way that it's simple for the users to locate older archived files.
Another area where I am struggling is the VMDK backups which are huge (ESXRanger), furthermore I would like to use disk based archival instead of tape. Offsite backups are achieved via a WAN link (although it's not wide enough for VMDK's)
I have two options I can buy another 2950 III (£900) add a MD1000 DAS (£3000) unit to it and rack it full of SATA disks, or I can buy a storage enclosure fill it with SATA disks £2000. I am leaning to the home build, the unit is not mission critical.
Down the line I am interested in converting the storage unit, SATA II with 12 spindles is plenty fast, into an ISCSI software SAN using Datacore or LeftHand. I would then build another unit in our second site and use delta level changes to sync the two providing true site disaster recovery, the most expensive thing being the licenses for the SAN.
Edit: Found a place I can buy enclosures and, looking to use http://forum.open-e.com/showthread.php?t=1139 - looks very promising for what we need. Async replication, going to be interesting to test.
Another thread I found for reference: http://forums.overclockers.co.uk/showthread.php?t=17941517
