- 7 Oct 2008
- Birmingham
Setup:
EKWB 250x3 res -> D5 pump /w EKWB top -> XSPC 480 radiator -> GTX 1080 /w EKWB -> 7600k /w EKWB supreme HF. Mayhems pastel yellow coolant.
Idle temps around 25-28*C for both the GPU and CPU.
Load GPU can get up to 80*C after a few hours of destiny 2, CPU getting up to around 60.
Everything running on stock.
Although the WC hardware is a bit old, I can't imagine it failing to keep up this much. I'd be inclined to think the seat of the blocks if fine given that the idle temps are only a few degrees above ambient.
At the moment, I'm thinking it may be that the fans are old/not working very well. Two are 120mm silverstones that came with my TJ07, the other two are Yate Loon D12sm, all four at 7v via 3 pin to molex. Occasionally I notice that one of the silverstones isn't running until I give it a little flick to start up.
I'm thinking of changing it to phantek PH F120SP as they can be had from a competitor for around a fiver and I find it difficult to justify ~£80-£100 on four fans.
Thoughts?
Thoughts?
