Large Non-Vesa fittings for 32"
23 Apr 2009
Caerphilly
Hi there,
I have the AOC Q3279VWF, which has no VESA mount points.
It's a pretty large monitor overall... I need to have it sit vertically next to my other 27" screens.
Does anyone know of a NON-VESA adapter/arm that would fit around this sized monitor and for it to fit while it's vertical?
Wonder if any of you monitor gurus know or have seen one of these please.
You know what, i actually overlooked that, simply because it looked like a VESA mount, where I don't have the holes.
Looking into it more - it can see it clamps to the read leg of the stand that's not removable! Brilliant!
I'll get one of those. Thanks dude.
Mark
I hope it's okay to ask this here as you've got your answer and I've got the exact same question but just with a different monitor so I didn't want to open a new thread - I have a Samsung LS32E590C 32" Curved Monitor and I was wondering whether anyone knew of any non vesa mount adaptors that would fit my monitor as I bought a dual mount with a new 27" monitor that I knew would fit, thinking that I could mount my old Samsung one next to it, only to realise like an idiot that the Samsung one wouldn't fit as the spacing between the holes is too far apart?
Something like the one linked on Amazon above would be fantastic as that's just what I need but it doesn't look like it would fit mine.
I really appreciate any help with finding one as I've been searching for a while now and can't find what I need.
Thank you!
Thank you!
According to the Samsung's specs, that monitor has a VESA mount. Found a photo... is this your monitor? Don't you have those 4 holes in the back?
