- 11 Jan 2011
Hi,
Im going to attempt to build a Computer Desk Case something like this.
http://cdn5.howtogeek.com/wp-content/uploads/gg/up/sshot4de8e8226da42.jpg
Im going to using a water cooled setup but i also want to include as many fans as possible to keep temps down to a minimum.
I do want to make this as quiet as possible however, so im looking to see what ultra quiet fans are available.
I come across these which seem to have excellent reviews.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-046-AE&tool=3
Are there any others i should consider?
i was thinking of putting 9 of these fans maybe more at the very bottom of the case to keep the underneath nice and cool, adding fans on both sides and on the rear but not on the front. and a glass lid.
But i will be cooling the CPU and graphics cards with a water cooled setup.
I will be starting off with 1 graphics card but will be adding more maybe up to 4 eventually so the whole system is going to be hot and i will be overclocking the cpu so looking to keep everything as cool as possible.
What you think?
Am i going a bit OTT on fans?
should i just stick with water cooling only?
Thanks
What you think?
Thanks
