** LARGEST RANGE OF IN STOCK 9xx SERIES AT OcUK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK has the largest range of IN STOCK 9xx series I believe worldwide and we also have more UK exclusives than anyone else.
See below all of our IN STOCK 9xx series cards:
asus geforce gtx 980 "reference design" 4096mb gddr5 pci-express graphics card @ £469.99 inc vat
the new nvidia geforce gtx 980/970 is powered by the next generation nvidia maxwell architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
maxwell is the most advanced gpu architecture ever made, designed to be the engine of next generation gaming. inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. for the first time, gaming gpu's can dynamically render indirect light using the new vxgi (voxel global illumination technology). scenes are significantly more lifelike as light interacts more realistically in the game environment.
the gtx 980 is the worlds fastest gpu and the gtx 970 offers the most advanced performance in its class. each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
enable the detail of 4k monitors, on a 1080p display. dsr produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
geforce gtx 980 and 970 cards support tear-free, super-fast nvidia g-sync monitor display technology including 4k. together, these technologies provide the most immersive and competitive gaming experiences possible.
features:-
- voxel global illumination technology (vxgi)
- nvidia® super resolution technology
- nvidia® gameworks technology
- nvidia® gamestream technology
- nvidia® txaa technology
- nvidia gpu boost 2.0
- nvidia physx® technology
- nvidia fxaa technology
- nvidia adaptive vertical sync
- nvidia surround
- support for four concurrent displays including: two dual-link dvi, hdmi and displayport 1.2
- microsoft directx 12
- nvidia® 3d vision® ready
- nvidia sli® ready technology
- nvidia cuda® technology
- pci express 3.0 support
- opengl 4.4 support
- opencl support
- nvidia shield ready
- nvidia g-sync ready
specification:-
- geforce gtx 980
- gpu: geforce gtx 980 (gm204)
- core base clock: 1127mhz
- core boost clock: 1216mhz
- memory clock: 7010mhz
- memory size: 4096mb gddr5
- bus type: pci express 3.0
- memory bus: 256-bit
- cuda cores: 2048
- directx 12: yes
- dvi port: 1x dual-link dvi, 3x displayport & 1x hdmi
- displayport: yes
- hdcp: yes
- hdmi: yes
- dimensions: 268.6 x 98.4 x 40 mm
- power: 2x 6-pin
- 500w psu required
- 178w tdp
- warranty: 3yr
only £469.99 inc vat.
order now
asus geforce gtx 980 directcu ii oc strix 4096mb gddr5 pci-express graphics card @ £479.99 inc vat
features:-
- nvidia surround
- opencl support
specification:-
- geforce gtx 980
- core base clock: 1178mhz
- core boost clock: 1279mhz
- cuda cores: 2048
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 2x -pin
- 500w psu required
- 178w tdp
- warranty: 3yr
only £479.99 inc vat.
order now
evga geforce gtx 980 superclock acx 2.0 4096mb gddr5 pci-express graphics card (04g-p4-2983-kr) @ £499.99 inc vat
the new evga geforce gtx 980 is powered by the next generation nvidia maxwell architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
features:-
- nvidia surround
- opencl support
specification:-
- geforce gtx 980
- core base clock: 1266mhz
- core boost clock: 1367mhz
- cuda cores: 2048
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 2x 6-pin
- 500w psu required
- 178w tdp
- warranty: 3yr
only £499.99 inc vat.
order now
galax geforce gtx 980 soc gamer 4096mb gddr5 pci-express graphics card (98nqh6dnc7vz) @ £419.99 inc vat
features:-
- nvidia surround
- opencl support
specification:-
- advanced ir3595 digital pwm
- multi-layer ceramic capacitors (helps reduce coil whine)
- geforce gtx 980
- process: 28nm
- core base clock: 1228mhz
- core boost clock: 1329mhz
- cuda cores: 2048
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 2x 8-pin
- 500w psu required
- 165w tdp
- review 1: http://www.guru3d.com/articles-pages/galax-geforce-gtx-980-soc-review,1.html
- Review 2: http://hexus.net/tech/reviews/graphics/76361-galax-geforce-gtx-980-soc/
- Warranty: 2yr
Only £419.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £479.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 980 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
GIGABYTE WINDFORCE 3X 600W cooling system once again break the record and bring the air cooling capacity up to 600W by only using 2 slots heights. The WINDFORCE 3X 600W cooling system is equipped with five 8mm and one 6mm composite cooper heat-pipes , special fin architecture, unique blade fan design, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
GIGABYTE Flex display technology can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
With GPU Gauntlet™ Sorting, the Gigabyte SOC graphics card guarantees the higher overclocking capability in terms of excellent power switching. Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
Features:-
- WINDFORCE 3X 600W cooling system
- Flex Display Technology(patent-pending)
- Powered by NVIDIA GeForce GTX 980 GPU
- Integrated with industry's best 4GB GDDR5 memory 256-bit memory interface
- Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort*3
- BASE: 1228 MHz / BOOST: 1329 MHz
- System power supply requirement: 600W(with two 8-pin external power connectors)
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1228MHz
- Core Boost Clock: 1329MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 1x DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: L=312mm, W=129mm, H=43mm
- Power: 2x 8-Pin
- 600W PSU Required
- 220W TDP
- Warranty: 3yr
- Bit-Tech Review: http://www.bit-tech.net/hardware/graphics/2014/10/02/gigabyte-geforce-gtx-980-g1-gaming-review/1
ORDER NOW
Inno3D GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (N980-1DDN-M5DN) @ £429.95 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £429.95 inc VAT.
ORDER NOW
Inno3D GeForce GTX 980 "Herculez X3 Ultra" 4096MB GDDR5 PCI-Express Graphics Card (N98V-1SDN-M5DNX) @ £399.95 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- Includes HerculeZ Backplate!
- GeForce GTX 980
- Core Base Clock: 1152MHz
- Core Boost Clock: 1253MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £399.95 inc VAT.
ORDER NOW
Inno3D GeForce GTX 980 "iChill Herculez X4 Air Boss Ultra" 4096MB GDDR5 PCI-Express Graphics Card (C98U-1SDN-M5DNX) **OcUK Exclusive** @ £499.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1266MHz
- Core Boost Clock: 1367MHz
- Memory Clock: 7200MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Review: http://www.kitguru.net/components/g...980-ichill-herculez-x4-air-boss-ultra-review/
- Warranty: 3yr
Only £499.99 inc VAT.
ORDER NOW
MSI GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £449.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £449.99 inc VAT.
ORDER NOW
MSI GeForce GTX 980 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £439.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1216MHz
- Core Boost Clock: 1317MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 200W TDP
- Warranty: 3yr
Only £439.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £425.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £425.99 inc VAT.
ORDER NOW
Palit GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (NE5X980015G2-PG401F) @ £429.95 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Palit GeForce GTX 980 JetStream 4096MB GDDR5 PCI-Express Graphics Card (NE5X980014G2-2042J) @ £449.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
Palit GeForce GTX 980 Super JetStream 4096MB GDDR5 PCI-Express Graphics Card (NE5X980H14G2-2042J) @ £469.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1203MHz
- Core Boost Clock: 1304MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £469.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (ZT-90201-10P) @ £429.95 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 165W TDP
- Warranty: 5yr (2yr +3yr FREE when you register the product with Zotac within 28 days of purchase)
ORDER NOW
Zotac GeForce GTX 980 AMP OC 4096MB GDDR5 PCI-Express Graphics Card (ZT-90204-10P) @ £419.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1165MHz
- Core Boost Clock: 1266MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 165W TDP
ORDER NOW
Zotac GeForce GTX 980 AMP Omega Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90202-10P) @ £479.99 inc VAT
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1202MHz
- Memory Clock: 7046MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 200W TDP
ORDER NOW
Zotac GeForce GTX 980 AMP Extreme Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90203-10P) @ £529.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1291MHz
- Core Boost Clock: 1393MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 209W TDP
Only £529.99 inc VAT.
ORDER NOW
Asus GeForce GTX 970 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card @ £305.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1114MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin
- 450W PSU Required
- 225W TDP
- Warranty: 3yr
Only £305.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 970 Superclock 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-1972-KR) @ £289.99 inc VAT
Features:-
- Radial fan blower design, better for SLI configurations and lower temperatures but at expense of being louder than NV 980 cooler and custom designs
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1140MHz
- Core Boost Clock: 1259MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x Mini-DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £289.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 970 SC ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2974-KR) @ £281.99 inc VAT
Features:-
- EVGA ACX 2.0 Cooling: With optimized swept fan blades, double ball bearing and an extreme low power motor, EVGA ACX 2.0 delivers more airflow with less power, unlocking additional power for the GPU.
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-pin
- 450W PSU Required
- 170W TDP
- Warranty: 3yr
Only £281.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 970 SSC ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2975-KR) @ £299.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1190MHz
- Core Boost Clock: 1342MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £299.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 970 FTW ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card with FREE EVGA X10 TorQ Laser Gaming Mouse (04G-P4-2978-KR) @ £319.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £319.99 inc VAT.
ORDER NOW
GALAX GeForce GTX 970 4096MB GDDR5 PCI-Express Graphics Card - OEM (97NPH6DT6XTZ) @ £247.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1050MHz
- Core Boost Clock: 1177MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £247.99 inc VAT.
ORDER NOW
GALAX GeForce GTX 970 4096MB GDDR5 PCI-Express Graphics Card (97NPH6DT6XTZ) @ £251.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £251.99 inc VAT.
ORDER NOW
GALAX GeForce GTX 970 EX OC 4096MB GDDR5 PCI-Express Graphics Card (97NQH6DNB4UX) @ £269.99 inc VAT
Features:-
- Extreme factory overclock
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1126MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £269.99 inc VAT.
ORDER NOW
GALAX GeForce GTX 970 EX OC "Black Edition" 4096MB GDDR5 PCI-Express Graphics Card (97NQH6DNB4TX) @ £289.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1164MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
ORDER NOW
Gigabyte GeForce GTX 970 WindForce OC 4096MB GDDR5 PCI-Express Graphics Card (GV-N970WF3OC-4GD) @ £289.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
Gigabyte GeForce GTX 970 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
Features:-
- WINDFORCE 3X cooling system
- Powered by NVIDIA GeForce GTX 970 GPU
- BASE: 1178 MHz / BOOST: 1329 MHz
- System power supply requirement: 550W (with one 6-pin and one 8-pin external power connectors)
- NVIDIA Surround
- OpenCL support
- Flex Connectivity (Upto 6 Monitors)
Specification:-
- GeForce GTX 970
- Core Base Clock: 1178MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
Inno3D GeForce GTX 970 OC 4096MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1088MHz
- Core Boost Clock: 1228MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £259.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 970 "iChill Herculez X4 Air Boss Ultra" 4096MB GDDR5 PCI-Express Graphics Card (C97U-1SDN-M5DNX) **OcUK Exclusive** @ £299.99 inc VAT
The GeForce® GTX™ 970 is a high-performance graphics card designed for serious gaming. Powered by new NVIDIA® Maxwell™ architecture, it features advanced technologies and class-leading graphics for incredible gaming experiences.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Boost Clock: 1305MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1 x DVI, 3 x DP and 1 x HDM
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £275.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Boost Clock: 1279MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £275.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 970 "NVIDIA 970 Cooler" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** @ £319.99 inc VAT
nonl2br
This very special NVIDIA GeForce GTX 970 is the only one of its kind designed by our in-house VGA Guru Gibbo making this the worlds ONLY genuine reference 970 available in the world. Gibbo's design request were very specific, genuine NVIDIA 970 cooler, yes the crazy expensive one just like the 980 cooler and a NVIDIA BGA Board using all original NVIDIA components with absolute zero cost down in the design.
<br>
<br>
Infact Gibbo improved the design by changing the containers in which the inductors are located for better quality items to help reduce and eliminate any possibility of coil whine. We also instruct our factory to only build these cards with Samsung memory. So why buy this over any other 970, well it is most likely the quietest whilst under load (gaming) due to having the NVIDIA cooler and any chances of coil whine have being pretty much eliminated with the design changes Gibbo has had implemented.
<br>
<br>
So this card is ideal for those seeking as little noise as possible and the other major advantage is the NVIDIA cooler which offers much better cooling performance in smaller enclosures or when running in 2-way or 3-way SLI.
<br>
<br>
Finally of course this card is perfect for when Half Life 3 is finally released at somepoint in the fuiture and of course the latest GTA V game which is now confirmed!
<br>
<br>
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.<br /><br />
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.<br /><br />
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.<br /><br />
Features:-<br />
- Voxel Global Illumination Technology (VXGI)<br />
- NVIDIA® Super Resolution technology<br />
- NVIDIA® GameWorks technology<br />
- NVIDIA® GameStream technology<br />
- NVIDIA® TXAA Technology<br />
- NVIDIA GPU Boost 2.0<br />
- NVIDIA PhysX® Technology<br />
- NVIDIA FXAA Technology<br />
- NVIDIA Adaptive Vertical Sync<br />
- NVIDIA Surround<br />
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2<br />
- Microsoft DirectX 12<br />
- NVIDIA® 3D Vision® Ready<br />
- NVIDIA SLI® Ready Technology<br />
- NVIDIA CUDA® technology<br />
- PCI Express 3.0 support<br />
- OpenGL 4.4 support<br />
- OpenCL support<br />
- NVIDIA SHIELD Ready<br />
- NVIDIA G-Sync Ready<br />
<br /><br />
Specification:-<br />
- Genuine NVIDIA 970 Cooler with Visualizer<br />
- Genuine NVIDIA 980 PCB<br />
- Samsung memory guaranteed<br />
- Coil Whine reduction technology: We specify the capacitors/inductors to be enclosed in plastic containers as it helps reduce/eliminate coil whine<br />
- GeForce GTX 970<br />
- GPU: GeForce GTX 970 (GM204)<br />
- Core Base Clock: 1050MHz<br />
- Core Boost Clock: 1178MHz (Upto 1268MHz Boost)<br />
- Memory Clock: 7010MHz <br />
- Memory Size: 4096MB Samsung GDDR5<br />
- Bus Type: PCI Express 3.0<br />
- Memory Bus: 256-bit<br />
- CUDA Cores: 1664<br />
- DirectX 12: Yes<br />
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI<br />
- DisplayPort: Yes <br />
- HDCP: Yes<br />
- HDMI: Yes<br />
- Power: 2x 6-Pin<br />
- 450W PSU Required<br />
- 145W TDP<br />
- Warranty: 3yr<br />
<br />
<br />
<br />
<br />
<a href="http://www.overclockers.co.uk/showproduct.php?prodid=LS-000-OK"><img src="http://www.overclockers.co.uk/LP/images/ocukimgh04.png"></a>
ORDER NOW
Palit GeForce GTX 970 4096MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1051MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
ORDER NOW
Palit GeForce GTX 970 JetStream 4096MB GDDR5 PCI-Express Graphics Card @ £275.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
ORDER NOW
Zotac GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90101-10P) @ £259.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1076MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 145W TDP
ORDER NOW
Zotac GeForce GTX 970 AMP Omega Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90102-10P) @ £299.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1102MHz
- Core Boost Clock: 1241MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 450W PSU Required
- 171W TDP
ORDER NOW
Zotac GeForce GTX 970 AMP Extreme Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90103-10P) @ £335.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Boost Clock: 1355MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 450W PSU Required
- 176W TDP
Only £335.99 inc VAT.
ORDER NOW
All the above cards are in stock! :)
Also remember the OcUK Price Match service on GTX 9xx series should you find a card cheaper elsewhere IN STOCK we will match their price, simply post your request in CS/Pre-Sales forum with a link to the competitor with stock at lower price and we will endeavour to match for you. Only available on GTX 9xx series! :)
Are the clocks any good on this? What's the max core people are getting :)
Gibbo, will you be getting any of those MSI 970 golden editions? Going to be limited to only 2000 worldwide, so I guess they'll command a premium.
I asked for these couple of weeks ago, the response was they are for Asian and USA market only and Europe will not get.
My response is you will give me what I want, I am your UK no.1 partner and I want this and if MSI value our relationship you will give me this card.
So they are working on trying to get me some, so we will have the EU exclusive on this but it will be like 20 units so yes the premium will be huge, like approx. £329 inc vat for one.
Thanks for the response.
Even with that heavy premium, with only twenty coming, I'd say they'll sell out in minutes!
Off to count my pennies...
There are so many choices now in the 970 range that I'm feeling positively discombobulated.
First I was looking at the MSI, Galax and Asus variants. Then the Galax black edition popped up.
Then the OCUK Milky Way Galaxy exclusive reference model turns up to further tempt me, and now the MSI Golden edition (which would fit right in with my colour scheme)!
:D dream on. fastest selling card in busiest month in retail of year :p
Not only that it is actually impossible to hit, would only happen if NVIDIA made an official price drop which they won't be doing ever or only when next generation comes and these are EOL.
And don't forget my own Black Edition card that I have designed from the ground up, I am testing my first hand made one now. Epic is beyond the word, so far upto 1620MHz core and 8500Mhz memory. :D
I should be designing cards for a living, seems I can do it better than the board partners. ;)
Wow, that sounds impressive.
You got any piccies of that?
Make it so.. just make sure it has 8GB or VRAM for future unoptimized titles lol :D
yeah, more details pls! 980 version? :D
I would be surprised if anyone would consider anything other than an Inno3D for £399, other 980's seem horribly over priced in comparison with the exception of the GALAX
Question :
I think the Gigabyte G1 will be too big for my case, so which other card would you recommend that has great overclocking potential?
