Lasagne low carb high protein!
I think you'll struggle to keep carbs low with lasagne :p
You could use wholemeal pasta instead of white, but the carbs are still there, albeit better ones.
Think I need to get this clear. Turkey slices, like as in out of a packet? Or slices of turkey carved from a....turkey?
Sounds interesting though, if a little wierd!
I've seen the same thing. As far as I remember it was very thin layers of turkey compacted into a similar style as normal lasagne sheets.
Will have to look around and see if I can find the linky
How about slicing courgettes lenthways and drying them in an oven at about 100°C for 30 minutes just to remove a little water but not shrink them. Use the thin slices of courgette as a pasta replacement. You might manage to swap thin slices of a white mold goats cheese, cut whilst chilled or barely freezing, for your bechamel.
As a general rule when cooking with aubergine and courgette I regulalry dry them in theoven on a low heat before adding them late on to curries or stews it intensifies the flavour improves the texture and avoids the wateriness that can ruin them if overcooked.
I made my own bechamel with whole wheat floor, milk and little bit of butter and mozzarella and only had 1 layer of pasta sheets, guessing that helped. In the oven now hopefully comes out nice!
In these circumstances, I do the same as above, I normally just make it in a more shallow dish, and only use one layer of pasta. Should help cut some of the carbs out.
You could use a low fat mozzarella instead of the bechamel, just break it up and use it for layers. Use Quorn mince or a do a vegetarian lasagne and wholemeal pasta and you won't be doing too bad.
How is removing the sources of good fat and protein going to reduce the carb content?
Use arrowroot to thicken the sauce instead of a flour/butter roux.
I've used thinly sliced aubergine before instead of pasta, worked really well although technically isn't lasagne since there's no pasta.
Red sauce:
Lean Beef Mince
2 x Red peppers
2 x onions
4 x cloves of garlic
2 x 500ml Jar of Dolmino extra vegetable ( Guess just 2/3 tins of chopped tomoatoes with carrots, sweetcorn etc would be healthier but i had some jars that i wanted to use up)
Layers:
Use chicken slices
White Sauce:
Extra thick double cream 300ml
250g of cheese
redsauce
Layer
White sauce
Redsaice
Layer
White sauce with slices tomatoes.
Had it with Broccoli and Cauliflower
Makes about 4-6 servings
