Laser mouse mat
20 Jul 2006
I have a razer copperhead and i am looking for a mat for it, the table is wearing out and to be honest the pointer is getting jumpy and ** Please fully star out swearies ** me off.
I am not looking to spend a fortune but i don't want a fabric mat as they are not easy to clean and i would be nice to have something of a reasonable size.
So any ideas???
I use a Razer Goliathus, not for gaming but for photoshop, the mat is 450mm x 350mm & great for my needs, maybe a little bit big but if you have the desk space then would recommend it. It is a fabric mat but before I used to use the Razer eXact Mat Speed (a hard coated double sided metal mat, smooth & grained) & I hated it & went back to fabric. Although I agree cleaning them as well as the little snags they get can be a nuisance but regardless it's fabric/rubber all the way for me when it comes to MM's.
Nothing wrong with a fabric mat. As for difficult to clean, from what exactly? And I just bunged my last one in the washing machine at the lowest temp.
BoogieBug XL for me :) perfect tracking with my G5 :)
If they get a snag, I just run my razor over it, that smooths it off again :D lol
(same trick works with bobbling on a jumper - shave it off ;))
any fabric one side rubber the otehr side mouse mat will work great about 79p from a competitor so cannot link the ones I use... last about 9 months or heavy use so buy a few..!
