need some help getting a family members PC to fix tomorrow been told the problem but got no idea how to fix it except to reformat it.
when they switch the PC on you get the windows loading screen & then get a error message about the lass.exe & to click ok to terminate. You can click on ok the message goes & all you are left with is a black screen & the mouse arrow.
Its the same when trying to go in to safe mode you only get the mouse arrow. ctrl+alt+del wont bring anything up.
the OS is XP but boot disc's have been lost & i might be able get get a boot disc from a mate if that would help.
I do really need to try & fix the problem as they have photo's on the PC that need saving.
If i do have to reformat what would be the best way to recovery the pictures after wards
Cheers
Cheers
