Last level of Prey - Advice please
1 Dec 2005
Stoke on Trent
Im on the last level of prey and im at the bit with the sphere. Im in a craft with like a sparkplug as a weopon. Ive sussed that i need to light all the things using the weopon.
Ive done all but 2 of them and they seem impossible to do. Do you need to be close to them or something?
Yes, you need to shoot yourself forward then light them, they do all light. :)
is it the bit where the woman is inside it and its spinning? shoot all the glass to get it to 'frost' then shoot them and they will shatter.
i got stuch here too.
Just use the 'dive' mode to get in close and blast them. Remember there is a short delay so you need to think ahead a little.
No matter what i do i just cant seem to get close enough to the last two fuses, i can move up and down the main wall, and launch myself at the sphere but the fuses i want are not reachable.
Am i missing something oobvious, as the craft isnt very manourverable
Wait for the right moment(once the one you want to hit comes around and quickly zoom in and blast em) zoom back out and dodge the harmful rays.
The sphere should be rotating & you should get a shot.If you can`t reach them maybe reload last before that?
Ive tried that but the ones i want always seem to be at the wrong angle and rotate the wrong way. I will have another go in the morning :)
