Lastest BeQuiet Modular Range - Excellent Value
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
The new L8 series of Pure Power PSU's from BeQuiet are available to buy now. With stock arriving next week. These units have the usual high end quality associated with the brand but are much more aggressively priced.
They offer 80 Plus Bronze certification and a modular design. Look at these against the same rated modular units from Antec, Corsair etc and you will agree these are great value.
BeQuiet Pure Power L8 430W '80 Plus Bronze' Modular Power Supply @ £47.99 inc VAT
When designing the Pure Power Series, our developers in Germany concentrated on the most important features for standard applications such as reliability and secure operation.
The Pure Power L8-430W has been engineered with the same high quality that you have come to know and appreciate from be quiet!. The usual quiet operation thanks to a high-quality temperature-controlled 120mm fan and the usual stable performance thanks to two separate 12V rails.
- Quiet operation through be quiet! fan using SilentWings technology
120mm fan with flow-optimised fan blades for enhanced airflow and exceptionally quiet operation. Especially quiet thanks to optimised rotational speed throughout the working range. Quiet operation and long lifespan of up to 100,000 hours thanks to a high-quality bearing and an individually balanced fan wheel.
- High performance and stability for CPU and GPU
Two independent 12V cables. Suitable for SLI and Crossfire multi-GPU operation. Supports the latest generations of processors from Intel® and AMD.
- Efficient and economical operation
80PLUS bronze certification for top efficiency of up to 88%. ErP ready. Stand-by energy consumption <0.5W.
- Very high compatibility with older and future components
12V P8 connection (P4+4). Four PCI express connections.
- Convenient to use. Cable management
Modular cable management system with numerous connection options. Modular, coated cable. All-in-one cable with S-ATA, HDD and FDD plug on one wire.
- Top safety and reliability
Maximum protection of components (OCP, OVP, UVP, OPP, OTP and SCP). Certified based on international safety standards.
- Service
2 years manufacturer‘s warranty
Only £47.99 inc VAT.
ORDER NOW
BeQuiet Pure Power L8 530W '80 Plus Bronze' Modular Power Supply @ £59.99 inc VAT
The Pure Power L8-530W has been engineered with the same high quality that you have come to know and appreciate from be quiet!. The usual quiet operation thanks to a high-quality temperature-controlled 120mm fan and the usual stable performance thanks to two separate 12V rails.
- Service
Only £59.99 inc VAT.
ORDER NOW
BeQuiet Pure Power L8 630W '80 Plus Bronze' Modular Power Supply @ £69.98 inc VAT
The Pure Power L8-630W has been engineered with the same high quality that you have come to know and appreciate from be quiet!. The usual quiet operation thanks to a high-quality temperature-controlled 120mm fan and the usual stable performance thanks to two separate 12V rails.
- Service
Only £69.98 inc VAT.
ORDER NOW
BeQuiet Pure Power L8 730W '80 Plus Bronze' Modular Power Supply @ £82.99 inc VAT
The Pure Power L8-730W has been engineered with the same high quality that you have come to know and appreciate from be quiet!. The usual quiet operation thanks to a high-quality temperature-controlled 120mm fan and the usual stable performance thanks to two separate 12V rails.
- Service
Only £82.99 inc VAT.
ORDER NOW
You now may want to go round updating the 'Pluus' to 'Plus' but apart from that, look rather good. And modular is quickly becoming a requirement nowadays!
Seems I had a stutter when typing today :)
Those are good value :) I would definitely give them serious consideration if I needed a PSU right now. I have a couple corsair modular ones bough 2 or 3 years ago for very similar prices so bearing in mind VAT was 15% then I think and that everything has gone up now anyway with higher production and transportation costs, these really are very good spec for the money :)
Very good value indeed. Am in the market for a modular PSU to help my airflow and these look bang on. I know they are bronze rated but are nearly half the price of the Corsair gold rated ones!
