Latency Timings
10 Feb 2022
Westmidlands
Good afternoon all
I need some advice on latency timings. I have had a new build (self built) for about a month now and had no issues up until yet. I'm using a Gigabyte B650M Gaming X AX Motherboard along with FURY Beast EXPO RGB 32GB (2x16GB) DDR5 PC5-48000C36 6000MHz RAM. The memory doesn't appear on the Gigabyte tested list, however they state, just because it isn't there doesn't mean it wont work. I've had a few crashes, when playing online and AMD Adrenalin reports an issue, the screen goes white and I have to hit the rest button. I have installed a Sapphire Nitro RX 7800 XT. I was wondering is it an issue with Latency?
I have EXPO turned on. High bandwidth support is disabled and my timings are 36-44-44.
Can anyone see a problem here? your thoughts please.
well, if crashes are regular/repeatable enough, you could turn off XMP and see if crashing continues. If it does, memory is not the cause.
Done that. Used TestMem before I changed anything, with no errors. Reset bios, turned on expo and tested again, no errors. See how it goes, I suppose.
if TM5 finds no errors then the ram is fine.
when you update bios you should alwasy reset the defaults after the update can change some values.
