Just upgraded to 1.09.01.00 on the X1C and then 00.00.06.75 on the AMS (separately as the AMS was unintentionally unplugged when I did the X1C). Now, I can't load any filament. Anyone else seeing anything similar or know of any other causes?
When it loads filament from the AMS for a print job, it feeds it all the way to the extruder, then all the way back, then back to the extruder, then back. Does this a few times and then declares it cannot extrude so the nozzle must be clogged.
Bypass the AMS and hand load and it works fine. As far as I can tell, the extruder is trying to feed the filament but the AMS (or maybe the buffer) is hanging onto it tight so the extruder can't feed anything. I've loaded as an external filament and printed a couple of jobs with no problem...it just won't from the AMS. The cable to the buffer and then onto the AMS are plugged in and the spring-loaded part in the buffer moves fine.
