That one is time limited, mind.sunlitsix said:you want the one called
"Creative Sound Blaster X-Fi series Beta Driver with OpenAL support"
Shakey_Jake33 said:That one is time limited, mind.
http://files.filefront.com/ISO_SB_X_Fi_series/;5020773;;/fileinfo.htmltweakinfreak said:Any idea's where you can get the fancy software package download for the XFI xtreme card?
I have the lastest beta drivers from creative but as I got an OEM card I don't get the nice front end programs that I saw in the reviews prior to buying the card..
?? Anyone know where I could download from?
Fanks
squiffy said:Wow, pretty unbelievable OEM is a cut down version.![]()
I would only need 2 channel, not EAX, 4 channel...just going to be plugged into a Hi-Fi system, heard that M-Audio (I have a Revo 5.1 in the HTPC) doesn't support hardware mixing so requires CPU processing.
