LATEST SAMSUNG PLUM MONITOR RANGE IN STOCK
17 Oct 2002
Stoke
Samsung's new range of LCD panels offer improved colours, sharper detail and power-efficiency features.
Samsung B1930NW 19" Widescreen LCD Monitor @ £123.99 inc VAT
Samsung 30 Series monitors are designed to be eco-friendly as well as user-friendly. With efficient power saving and innovative features, they allow you to enjoy using your monitor with the confidence of a clear conscience. The phenomenal 50000:1 Dynamic Contrast Ratio welcomes you to a world of intense, natural colour and incredible, lifelike detail. Combine that with a high brightness of 300cd/m² and you have a monitor that is made for multimedia.
- Screen Size: 19" Widescreen
- Resolution: 1440x900
- Contrast Ratio: 70000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue
- VESA Compliant
- Dimensions: 458.0mm x 402.0mm x 178.0mm
- Weight: 3.95kg
- Warranty: 3 Years On-Site
Only £123.99 inc VAT.
ORDER NOW
Samsung B2230H 21.5" Widescreen LCD Monitor @ £169.99 inc VAT
Samsung 30 Series monitors are designed to be eco-friendly as well as user-friendly. With efficient power saving and innovative features, they allow you to enjoy using your monitor with the confidence of a clear conscience. The phenomenal 70000:1 Dynamic Contrast Ratio welcomes you to a world of intense, natural colour and incredible, lifelike detail. Combine that with a high brightness of 300cd/m² and you have a monitor that is made for multimedia.
- Screen Size: 21.5" Widescreen
- Resolution: 1920x1080
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 523.4mm x 400.0mm x 197.0mm
- Weight: 4.35kg
Only £169.99 inc VAT.
ORDER NOW
Samsung B2430L 23.6" Widescreen LCD Monitor @ £193.99 inc VAT
- Screen Size: 23.6" Widescreen
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 582.0mm x 448.0mm x 197.0mm
- Weight: 5.2kg
Only £193.99 inc VAT.
ORDER NOW
Omg their pretty damn impressive for the cost, shame I jsut bought a new monitor a few weeks ago :/ or else I woulda snapped the 24" in a snap.
Does anybody have any links to independent reviews of these monitors? I know Samsung generally tend to be high quality, but I haven't heard of this range before and I can't find any reviews online.
I couldn't either unfortunately. I quite like the B2230H but I'd be a little apprehensive buying it without seeing any reviews.
What does "plum" refer to? Is it just a name they chose for the range, or do the monitors have a tint of plum? They look black but I just want to check!
It says pre-order for the 21.5" B2230H. I'm looking to purchase this monitor with the rest of my build tomorrow, any idea when it will be back in stock?
Why do Samsung always put these horrible bezel designs on their monitors?
Specs look solid anyway at that price.
samsung reviews please......i cant make my mind up between Samsung B2430L 23.6" and the Dell ST2410 24"
If anyone can help in anyway it would be a great help!
thanks ^^
thanks ^^
It might be too late but the B2230H I ordered just came back into stock so I should have it next week providing Asus supply the R3E motherboards to OcUK.
I know it's not the same size, but the 21.5" will be using the same panel tech. as the 23.6", so I'll let you know what I think of it next week if you're still interested.
