LaTeX paragraphs
18 Mar 2007
Hey,
Is there a way to make Latex start a paragraph by default without an indent and on a new line, with an empty line in-between? I'd rather have it do this than the default new line and indent.
Have had a quick google around but can't find anything. Anyone got any ideas?
Thanks
I would just do: \newline\noindent Paragraph text here.
Any good? There is also a way to disable paragraph indents I think.
Paragraph indentations: By default (in most document classes), all paragraphs except for the first paragraph in a section are indented. To disable the indentation, set the "parindent" parameter to zero, by adding this to the preamble:
\setlength{\parindent}{0in}
To add additional spacing between paragraphs, set the "parskip" parameter to an appropriate value. For example:
\setlength{\parskip}{10pt}
If you want it applied to every paragraph in the document, add the following two lines to the top of your file:
\setlength{\parindent}{0pt}
\setlength{\parskip}{2ex}
*Edit* Damn, too slow!
