Lavas/Lafals/Lavals
13 May 2010
The big flat turkish bread that is about the same thickness as fajita wraps, but double the size...
Anyone know the correct spelling / pronunciation and where to get them?
-Rob
Lavaş (Lavaj Bread)
This is a bread made by baking yufka from leavened dough on the walls of a hot tandır. In the Sivas region it is baked in an oven. Lavaş bread is generally made in the regions of Erzurum, Kars, Muş, Konya (Yunak) and Erzincan.
After lavaş is baked, it is generally an ellipse 30-40 cm in length, 15-20 cm wide, and 1-1.5 cm thick, however it made sometimes be made in different sizes (7, 17, 18). In the region of Elazığ, it is known as tandır bread (19).
http://www.turkish-cuisine.org/english/pages.php?ParentID=5&FirstLevel=76
if its not that one you may well find it in that link
EDIT: might be lavash bread actually, google it
http://en.wikipedia.org/wiki/Lavash
It is Lav-ash in Persian/Farsi and you can pick it up in most Persian food shops. If you have a decent Persian restaurant nearby that bake their own bread then you can often get it from them too.
Traditionally the dough is rolled out flat and slapped against the hot walls of a clay oven. While quite flexible when fresh, lavash dries out quickly and becomes brittle and hard. The soft form is easier to use when making wrap sandwiches; however, the dry form can be used for long-term storage (almost one year) and is used instead of leavened bread in Eucharist traditions by the Armenian Apostolic Church. In villages in Armenia, the dried lavash is stacked high in layers to be used later, and when the time comes to rehydrate the bread, it is sprinkled with water to make it softer again. In its dry form, left-over lavash is used in Iran to make quick meals after being rehydrated with water, butter and cheese. In Armenia the dried bread is broken up into Khash. Fresh lavash is also used with kebabs to make dürüm wraps or in Armenia to make burum which are wraps with herbs and cheese. According to the Encyclopedia International, "Common to all Armenians is their traditional unleavened bread, lav-ash, which is a staple in the Armenian diet."[7]
Lavash is made with flour, water, and salt. The thickness of the bread varies and depends on how thin it's rolled out. Toasted sesame seeds and/or poppy seeds can be sprinkled on before baking.
It is the most widespread type of bread in Armenia, Azerbaijan and Iran.[8]
In Kashmir it is known as Lavase. It is one of the basic bread products and Kashmiri people consume it on a regular basis for breakfast. As a tradition, Kashmiri Pandits distribute lavase among neighbours, friends and relatives on several occasions as a symbol of good omen and abundance of food. Lavase pieces with green walnut kernels folded between them are considered a delicacy.
It is also known in English as lahvash or cracker bread.
