Lawn weed help!
23 Mar 2011
Hi all! Obviously need a mow again but whats with all the weeds! They seem to have appeared suddenly, is there a way of treating them while not damaging the grass or is it a case of just hand pkucking them out? They seem to have appeared over the last week or so!
Need to get on with the garden anyway its looking a mess but none of our neighbours lawns are like this and they were all laid at the same time year and a half ago, maybe they look after theres! .. lol
You can either mow it and they will eventually give up and die or you can buy a ready mixed bottle of roundup (Glyphosate) and spray on them, try and avoid the grass as it will kill that as well.
Or you could dig them up, roots of those I would imagine won't be too deep although there are a quite a few.
I used Verdone lawn weedkiller last year and was very impressed with the results. Only a tiny bit of grow back in a corner this year. Will be using it once a year anyway to keep everything at bay.
