Deleted User 298457
Deleted User 298457
Hi folks,
So the 50sqm of herringbone has arrived. I've already quickly learnt (thankfully) that there is an A and a B side. A quick video concurs with Flooring Direct's view that you make a triangle, cut the bottom off, and then these are your "starting points. I've then read that some installers glue the starting triangles with D3. The "kit list" for my boards says I need to have some PVA, but funnily enough, doesn't include any installation instructions lol.
Given I want to cover the entire downstairs, I am thinking this is going to be an absolute nightmare, lol. Is there any tips to getting started?
Floor plan:
^I am thinking I yolo it and try and get the "middle" of the herringbone pattern to line up with the french doors. But the instructions say I need to work from a corner "outwards". Does that mean I start from the "Entrance Hall" and work inwards?
I also have some minor differences in floor level; I was going to put some hardboard but I've since realised the subfloor is off level ~2mm on the left but more like ~4mm on the right. The floor itself is level, I just need to fill the space up.
Thanks.. will keep the thread updated.
Floor plan:
