** LAYING OUT SOME CABLE(S) FOR YOU **
OcUK Staff
23 Feb 2015
Overclockers UK HQ
Hi guys,
I've reduced the price on a load of cables, converters and powerbanks so we are the cheapest out there. Thought I'd drop a heads up here before the non-forum muggles out there snap them up.
This is stock that's either been sat there for a long time or we've found in the warehouse and it's a little dated. The Sandberg powerbanks are a steal, even though they are cheaper than the mass produced Chinese stuff out there they come with 5-year warranties.
C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Converter - Black (84313) @ £12.95 inc VAT
C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Converter - Black (84313) @ £12.95 inc VAT https://www.overclockers.co.uk/c2g-...-adapter-converter-black-84313-cb-023-cg.html
This adapter converter is an ideal solution for adapting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a HDTV or projector which accepts a HDMI input.
Only £12.95 inc VAT.
ORDER NOW
C2G 15cm Mini DisplayPort Male to DisplayPort Female White (84304) @ £7.99 inc VAT
C2G 15cm Mini DisplayPort Male to DisplayPort Female White (84304) @ £7.99 inc VAT https://www.overclockers.co.uk/c2g-...displayport-female-white-84304-cb-018-cg.html
Adapt the Mini DisplayPort output of a computer so that it may be connected to a computer monitor which accepts a DisplayPort input
Only £7.99 inc VAT.
ORDER NOW
Dynamode 4 Port HDMI Splitter V1.4 @ £29.99 inc VAT
Dynamode 4 Port HDMI Splitter V1.4 @ £29.99 inc VAT https://www.overclockers.co.uk/dynamode-4-port-hdmi-splitter-v1.4-cb-001-dn.html
Fully HDMI v1.4 compatible allowing you to connect an extra 4 HDMI cables to your TV/Montior.
Only £29.99 inc VAT.
ORDER NOW
Sandberg 12000mAh Power Bank @ £25.99 inc VAT
Sandberg 12000mAh Power Bank @ £25.99 inc VAT https://www.overclockers.co.uk/sandberg-12000mah-power-bank-cb-027-sb.html
Sandberg (420-20) 12000mAh Power Bank, 5V, USB, LED Flashlight, 5 Year Warranty
Only £25.99 inc VAT.
ORDER NOW
StarTech 10m Active DisplayPort Cable - DP to DP M/M (DISPL10MA) @ £52.99 inc VAT
StarTech 10m Active DisplayPort Cable - DP to DP M/M (DISPL10MA) @ £52.99 inc VAT https://www.overclockers.co.uk/star...t-cable-dp-to-dp-m-m-displ10ma-cb-100-sr.html
The DISPL10MA 10m Active DisplayPort® Cable features a built-in active signal booster for a connection distance of up to 30 feet (10m) between your DisplayPort-enabled devices
Only £52.99 inc VAT.
ORDER NOW
C2G 20cm Mini DisplayPort Male to VGA Female Adapter Converter - White (84316) @ £12.95 inc VAT
C2G 20cm Mini DisplayPort Male to VGA Female Adapter Converter - White (84316) @ £12.95 inc VAT https://www.overclockers.co.uk/c2g-...-adapter-converter-white-84316-cb-022-cg.html
This adapter converter is an ideal solution for converting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a computer monitor which accepts a VGA input
ORDER NOW
Sandberg 8000 mAh Outdoor Solar Powerbank @ £24.95 inc VAT
Sandberg 8000 mAh Outdoor Solar Powerbank @ £24.95 inc VAT https://www.overclockers.co.uk/sandberg-8000-mah-outdoor-solar-powerbank-cb-035-sb.html
Sandberg Outdoor Solar Powerbank, 8000mAh, USB & Solar Charging, Flashlight, Rainproof, 4 LED, 5 Year Warranty
Only £24.95 inc VAT.
ORDER NOW
Sandberg Solar Powerbank Excel @ £44.99 inc VAT
Sandberg Solar Powerbank Excel @ £44.99 inc VAT https://www.overclockers.co.uk/sandberg-solar-powerbank-excel-cb-036-sb.html
Sandberg Solar Powerbank Excel, 5000mAh, USB & Solar Charging, Splashproof, Stand, 5 Year Warranty
Only £44.99 inc VAT.
ORDER NOW
StarTech DisplayPort to HDMI Active Video and Audio Adapter Converter - DP to HDMI - 1920x1200 - White (DP2HDSW) @ £19.99 inc VAT
Sandberg 6000mAh Outdoor Powerbank @ £19.99 inc VAT
Sandberg 6000mAh Outdoor Powerbank @ £19.99 inc VAT https://www.overclockers.co.uk/sandberg-6000mah-outdoor-powerbank-cb-032-sb.html
Sandberg (420-27) 6000mAh Outdoor Powerbank, Waterproof, Dust-proof, Shock-proof, Flashlight, USB, 5 Year Warranty
Only £19.99 inc VAT.
ORDER NOW
Sandberg 18200mAh Powerbank @ £37.99 inc VAT
Sandberg 18200mAh Powerbank @ £37.99 inc VAT https://www.overclockers.co.uk/sandberg-18200mah-powerbank-cb-031-sb.html
Sandberg (420-26) 18200mAh Powerbank, Charge 3 Devices at Once, USB, 5 Year Warranty
Only £37.99 inc VAT.
ORDER NOW
StarTech DisplayPort™ to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black (DP2VGDVHD) @ £36.95 inc VAT
OcUK Value 2 Port 4K HDMI Splitter (NLHDSP402-HS4K) @ £17.99 inc VAT
StarTech 10 ft Mini DisplayPort™ to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black (MDP2DVIMM10B) @ £17.99 inc VAT
Sandberg 3000mAh Excellence Power Bank @ £14.99 inc VAT
Sandberg 3000mAh Excellence Power Bank @ £14.99 inc VAT https://www.overclockers.co.uk/sandberg-3000mah-excellence-power-bank-cb-033-sb.html
Sandberg (480-06) 3000mAh Excellence Power Bank, Micro USB & Lightning Connector, ThinLight, 5 Year Warranty
Only £14.99 inc VAT.
ORDER NOW
Akasa ATX 24-Pin to ATX 20-Pin Adapter Cable (AK-CB24-20) @ £0.95 inc VAT
IcyBox Adapter cable for two 2.5" SATA HDDs or SSDs to USB 3.0 (IB-AC622-U3) @ £14.99 inc VAT
IcyBox Adapter cable for two 2.5" SATA HDDs or SSDs to USB 3.0 (IB-AC622-U3) @ £14.99 inc VAT https://www.overclockers.co.uk/icyb...or-ssds-to-usb-3.0-ib-ac622-u3-cb-000-bt.html
Two are always better... Popular hard drive adapter is now available with slots for two 2.5" SATA hard drives (up to 9.5mm height).
ORDER NOW
i dont understand this one, I have HDMI to Display port cables that work fine and on my pc now a £4 pound display port to hdmi adaptor, what is the advantage of this one
I may be wrong about this but I'm guessing yours is a "passive" adapter rather than an "active" adapter. The terms passive and active are a bit misleading. Best information i found after a quick google were these paragraphs:
The “Type-1” adapters which are commonly sold as “passive” rely on the DisplayPort source (like a video card) supporting DisplayPort++ (aka Dual-mode). When certain pins are pulled up to 3.3 volts or down to ground through specific resistor values, the physical DisplayPort pins are programmed to output the HDMI/DVI TMDS protocol instead of the LVDS DisplayPort packet protocol. But the TMDS protocol is still output at 3.3 volts which won’t work with a DVI/HDMI monitor designed for 5 volts. So the type-1 adapters include active electronics to level shift the 3.3 volt signaling to 5 volts. The signaling is limited to 165MHz bandwidth so screen refresh rates and resolutions are limited too. Aside from the level shifters, additional electronics are needed to regulate power – typically the 3.3 volts supplied from the DisplayPort connector on pin 20 is boost-converted to 5 volts. There is also a circuit to handle the DDC communications as well. So there is a lot of stuff inside your “passive” DisplayPort adapter.
Type-2 adapters also pass-through the existing TMDS signal and level shift it from 3.3v->5v, but include more advanced integrated circuits and are able to operate at up to 300MHz with HDMI thus enabling 4K@ 30Hz output per HDMI 1.4 spec. Depending on the vendor, these adapters may be marketed as “active” or “passive” so you really need to read the fine print to understand the specs of the adapter.
Finally there are truly “active” adapters that do not rely on DisplayPort++/Dual-Mode at all. Instead they are able to decode the LVDS DisplayPort packet protocol in real-time and re-encode it into HDMI/DVI compatible TMDS protocol. DisplayPort->Dual-link DVI-D adapters are true “active” adapters. As are “EyeFinity” certified adapters. Some active adapters need to be powered by a USB port, however, most adapters available today are powered by pin 20 on the DisplayPort source which supplies 3.3 volts at up to 500mA. These truly active adapters are expensive but allow more flexibility with refresh rates and resolutions depending on which integrated circuit is used inside.
TLDR - Active adapters support both Multimode (DP++) and Single-mode DisplayPort output signals and higher refresh rates/resolutions.
