** LAZER3D CG7 CRAVO - 7 LITRES, SO MANY POSSIBILITIES **
OcUK Staff
26 Nov 2014
Stoke
Available to order today, we have the newest addition to the Lazer3D range - The CG7 Cravo. The CG7 Cravo is a mere 7.1 litres in size, yet like the LZ7 and HT5, offers huge amounts of possibilities for such a small chassis. For a start, the CG7 supports slim M-ATX boards (up to 244mm x 195mm) and up to 4 low profile PCIe cards, including dual slot low profile VGA cards up to 195mm in size. There's space for a 73mm CPU cooler and up to 4 slim 92mm case fans. There's options out of the box for either a Mini-ITX system with a TFX power supply, or Slim M-ATX using a DC-DC power supply, which gives you plenty of scope for creating your perfect SFF system. There's even space for up to 6 x 2.5" drives if you fancy building a NAS with a difference! The CG7 also supports Flex ATX power supplies with a provided bracket.
Added to that is the ability to customise your chassis panel, internal panel and front panel design, with over 150 combinations available. There's base panel sets in Black, Grey, Beige and White, internal panels in Black, Grey, Beige, White, Red, Orange, Violet, Yellow and Clear along with front panels available in 'Stealth', 'Graphite', 'Retro Gaming', 'Timber' and 'Bourbon'. All these can be configured quickly and easily using our configurator linked below. Materials used throughout are 5mm matte acrylic for the main panels, 3mm matte/coloured acrylic for the internal panels, and either 5mm solid wood or acrylic for the front panels.
Basically, the CG7 is another quality product from Lazer3D, manufactured in the UK, and comes with a set of instructions for easy self assembly. All variants are available and in stock today, but there's limited stock on certain things for launch, so if you need a CG7 in your life, I suggest you order soon :)
Lazer3D CG7 Cravo Slim Tower Case Configurator @ £139.99 inc VAT
Ultra compact and customisable SFF chassis with a flexible dual layout design for M-ITX or M-ATX systems.
From £139.99 inc VAT.
ORDER NOW
