** LAZER3D HT5 - 5.3 LITRES OF AWESOME **
OcUK Staff
26 Nov 2014
Stoke
We're proud to exclusively launch the newest addition to the Lazer3D range, the HT5. The HT5 is a Mini-ITX chassis that is a mere 5.3 litres in volume, yet supports various cooling options and low profile GPU's within it's compact yet stylish frame.
The HT5 is available in 4 distinct variations, Stealth, Graphite, Timber and Bourbon: -
- STEALTH - all Matte Black case with a Smoked Gloss top window panel, for subtle under the radar performance!
- GRAPHITE - a gritty mix of Matte Grey with a strip of brushed metallic effect plate across the front and a Clear Gloss top window panel.
- TIMBER - a combination of Solid Oak and Matte White panels with a Clear top window panel, Scandinavian inspired style.
- BOURBON - Solid Walnut Front Panel with Matte Black sides and Clear top window panel, a touch of luxury.
The panels are made from 5mm thick acrylic, along with 5mm solid wood front panels on the Timber & Bourbon models. Each model features a frosted cutout on the front panel that can be illuminated by a RGB motherboard with the appropriate lighting.
The HT5 has space for up to 4 x 80mm fans, and can support a 72mm CPU cooler if you fancy an APU setup, alternatively it can be configured to support a low profile GPU such as a 1050Ti. There are a lot of different configuration options available, some of which are highlighted in this diagram below: -
As you can see, the HT5 is compatible with DC-DC power supplies, freeing up crucial space internally for more configurations than you'd ever expect from such a small chassis. Depending on your configuration, there's space for up to 3 x 2.5" drives, with brackets included to mount them.
For those who would prefer a different top panel, there is also a bunch of alternative panels available to purchase separately, including both clear and smoked window panels, along with Black, White and Grey matte panels. Essentially, the HT5 is another killer addition to the Lazer3D lineup, and would be perfect for a compact HTPC system, or a tiny LAN ready e-sports system. The varied options available should suit most tastes, and frankly it's difficult to see a smaller, more feature rich case available on the market! Stock is available today!
Lazer3D HT5 Stealth Mini-ITX HTPC Case @ £89.99 inc VAT
The Lazer3D HT5 is an ultra compact & ultra stylish low profile Mini-ITX case that doesn't compromise on cooling performance and is perfect for a compact APU or low profile GPU setup.
Only £89.99 inc VAT.
ORDER NOW
Lazer3D HT5 Graphite Mini-ITX HTPC - Grey/Smoked @ £94.99 inc VAT
Only £94.99 inc VAT.
ORDER NOW
Lazer3D HT5 Timber Mini-ITX HTPC - White/Oak @ £94.99 inc VAT
ORDER NOW
Lazer3D HT5 Bourbon Mini-ITX HTPC - Black/Walnut @ £99.95 inc VAT
Only £99.95 inc VAT.
ORDER NOW
Lazer3D HT5 - Clear Window Top Panel @ £11.99 inc VAT
Alternative replacement top panel for the Lazer3D HT5 Mini-ITX case.
Only £11.99 inc VAT.
ORDER NOW
Lazer3D HT5 - Smoked Window Top Panel @ £12.95 inc VAT
Only £12.95 inc VAT.
ORDER NOW
Lazer3D HT5 - Black Matte Top Panel @ £13.99 inc VAT
Only £13.99 inc VAT.
ORDER NOW
Lazer3D HT5 - White Matte Top Panel @ £13.99 inc VAT
ORDER NOW
Lazer3D HT5 - Grey Matte Top Panel @ £13.99 inc VAT
ORDER NOW
Not seen those HDPLEX power whatnots they've designed the case for.
One is a 400W DC-DC board (how big a power brick for that o.0) and the other is a power brick you put in your case and attach to a DC-DC board, appears a pico style one in diagram.
Case layout is nice, often thought about something with a skinny psu one side and a gpu the other.
