 - 20 Dec 2008
My converter has died due to a power outage at the house, it came with the Belinea screen 6 years ago and I do not know the specs. You'd have a normal PSU lead and it would go into this converter and at the other end was a DC plug which went into the LCD.
I've found an old DC plug I used for recharging batteries and it seems to work fine powering the screen, I'm just worried it may be a 'weaker' DC plug or the opposite and due long term damage to my screen.
On the Converter it says:
Input: 100-240v 50/60HZ 1.7A
Output: 12v 4.16A
On the plug I'm using now that directly plugs into the mains:
Input: 100-240v 50HZ 85W
Output: 16v = 4A
I don't know what any of that means or if the plug will overheat and die. Can anyone help me out?
Output: 12v 4.16A
Output: 16v = 4A
