LCD knackered
9 Oct 2004
Paris
Hi all,
this is more of an ending to my previous post. So, i think its finally gone, it turns on, goes onto the BIOS crap, then turns off. Can't turn it on again. This has happened for about a week now. I'm sure its the power lead as before, I took it out and jamemd it back in again - worked. Now it just makes electricty noises :P
Sounds dangerous, what do I do? warranty/RMA? Or is it just a new power cable thingy?
Cheers.
No one got any ideas?
I think its finally done in now.. after moving the plug around/banging it etc (which used to work for a bit) it goes on for about 2/3 seconds and displays "no signal... somethingsomething"
Could it be the fuse? or is the whole thing need returning to Hydundai?
cheers
