My lad wants to take his PS3 into the realms of HD as he only plays it on a 28" SD TV at present.
He has to buy it himself but can't really afford anything special. I got an email from another website with a really decent offer on a 22" Widescreen TFT Monitor for £150. It has HDMI as well so I dont think there will be a problem running PS3 on it but I need someone on here who is in the know to see if it's all ok.
Specs as follows:-
Specifications
Product Description: HANNSG HG216DP 21.6" Widescreen TFT Monitor
Display size: 21.6" -Widescreen
Panel Type Active Matrix TFT
Resolution: 1680 x 1050
Response time: 5ms
Brightness: 300 cd/m²
Contrast ratio: 1000:1
Pixel pitch: 0,277 x 0,277mm
View angles: LR,UD H/V 170° / 160°
Display colours: 16.7M Colours
Dimension (W*D*H): 518 x 230 x 412 mm
Net weight 5.8 kg
Anyone know if there will be any problems with this monitor on a PS3? If he got it then he would replace his PC monitor rather than his TV so he would share connection with PC.
Specs as follows:-
Specifications
Response time: 5ms
Net weight 5.8 kg
